factory restore Vaio S
ChinaTownBoy
svs1312c5e - does anyone know how to factory restore this sony vaio s?
rich912
Hi ChinaTownBoy,
When fully shut down press the Assist button to launch Vaio Care rescue mode. Then select Recover or maintain your system - do NOT select the Refresh option as you will lose all Sony software.
Be aware that the factory reset will wipe all personal data.
Rich
Go n-éirí an bóthar leat
rich912
Hi ChinaTownBoy,
Rich
