hi everyone there,hope you are all getting ready for festive season.
anyone know how to send fax (receive) on broadband without disconnecting ethernet.
thanks
belgrave
You normally send a fax via your 56k modem
There are a number of programs that will allow you to send fax via email using XP – for a fee. There are also free utilities that will allow a limited number of free fax via email. Try a Google (faxing via broadband)…
Another alternative is to purchase a multi function printer that incorporates a fax facility.
thankyou i will check
belgrave
hi keelo thankyou.
i have a modem.can i connect to phone line and ethernet at the same time.
thanks mallepaddi
Yes you can, no problem with that
thank you keelo.i wasn't sure whether it will work
belgrave
No problem, happy faxing
