FE11-S Bluetooth configuration
ocatarineta
Hello,
does anyone know how to configure and use bluetooth connections? I don't know if in reinstalling a WinXP Pro I missed something. Lan Switch utility correctly switches on/off bluetooth, but... that's all I can do.
Thnx!
10 REPLIES 10
William
Is Sony Bluespace turned on too?
ocatarineta
... hmm ... what's sony bluespace?
William
This may help:
SONY BLUETOOTH
ocatarineta
Ok, got it. But on the recovery DVDs I cannot find anything that resembles me Bluespace...
kee-lo_
Bluespace is not on new VAIOs William, so don't worry about that.
If you go to control panel you should be able to manage bluetooth, and pair with the device
ocatarineta
In the control Panel I couldn't find anything specifically related to Bluetooth. In Network I can see a network connection for the bluetooth device, but nothing more than usual tcp/ip settings... Any idea about what to do?
Thnx!
kee-lo_
William
Kee-Lo, Thanks for the info reference Bluespace on newer models.
What happened to it? Did Sony finally give in?
and apologies to Ocatarineta for the misinformation.:smileysad:
kee-lo_
Ditched it by the looks of it, thank god!
