- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
FE11S Video driver update
Hello,
I'm wondering if there's any way to update the video driver for the 7400Go of my Fe11S.
The last posted by Sony is a 2006 driver (what a great support, Sony!), and I have many issues, mainly with the Adobe CS4 suite using a dual monitor configuration.
Any idea?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ocatarineta,
At your own risk you could try using a driver from LaptopVideo2Go, use the following link to view the list of drivers: LaptopVideo2Go
You will need to install a modded .inf, click the following for more info on: What is a modded INF?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for the suggestion,
I already tried this way but it's not 100% functional: es. you loose brightness control.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You're welcome, unfortunately that's the best we can offer as it's unlikely that Sony will release an update for your Vaio..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I know, this is the kind of reason why here at work we are no longer buying Sony.
Thank you anyway for your good and kind suggestion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I think the driver version 174.74 was the last version to be customised for Vaio Go 7400 and installs without a modified .inf - direct from an .exe file.
http://www.laptopvideo2go.com/drivers/9?os[]=xp
You will have to copy and paste the whole link to go direct to the correct page.
May be worth a try?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello,
thank you for the tip.
I did already try this, following what found here: http://forum.notebookreview.com/showthread.php?t=195238
Unfortunately this doesn't work on my laptop (maybe I miss something).
I'm wondering why Sony continues to make users not to be able to use generic drivers, since drivers support from sony is so poor...
Thank you again!!!
