New AR31S. Vista and AOL hate each other. Managed to get an internet connection for a day or two before they again decided on mutual aversion. Way forward? Talk to AOL. But first decided to uninstall AOL and then re-install to see if that worked. Now it gets difficult.
• Machine refuses to read it or any cd/dvd regardless of the fact it worked not long ago
• Cannot therefore try to install AOL
• As a consequence of no internet link cannot seek help from downloads. (Don’t get me started on not understanding routers, the other problems are probably stand alone)
• Sound has gone regardless again of the fact it worked not long ago
• Restore to earlier time doesn’t resolve
• Control panel check says no problem with cd/dvd or sound
• Did Vaio hardware diagnostic (found it by accident!) and was told errors detected that seemed to be usb. No detail or remedy seemed to be offered, no help there.
Although I have not – now could not – made/make back up recovery discs going attempt recovery. Or other (easy to follow please) suggestions.????
Apropos nothing probably, the machine has been virtually heat free all day.
I did hear that some of the supplied phone adapters are faulty. If you don't get a dialling tone try connecting without the supplied adapter.
PS Pandora - I appear to have kidnapped your thread - sorreee [:">]
