first time using recovery disks
vijsingh
Im about to use the recovery disks to get my Vaio to factory settings but im afraid of something going wrong and ending up with a dead Vaio.
Would there be a way around it if it did go wrong somehow?
8 REPLIES 8
If you make sure you keep the Recovery Partition on your hard drive and also make two or three sets of Recovery Discs, you should be safe enough.
Belts and Braces are recommended!
:wink:
vijsingh
:wink:
im not sure what that means :thinking:
oh i've made enough sets :smileygrin:
7hil
I've had Vaio's for 8 years now and whenever I get a new one I make to two sets of recovery discs and then delete the recovery partition. Never had any problems performing a recovery.
Thalamus.
Champion
Hi vaioAR61M,
the recovery disc's will probably work just fine..
On the of chance that something goes wrong simply remove the recovery disc's that you created and restart your Vaio then when you see the Vaio logo screen press F10 repeatedly this normally would start the recovery process using the HDD partition..
vijsingh
somehow I always seem to have bad luck with technology :slight_frown: so im just thinking ahead.
thanks
btw. what is this HDD partition/Recovery Partition? will a restore detete it?
Thalamus.
Champion
Your vaio has a hidden partition on your HD drive that contains the files needed to recover your Vaio..
If you only select the default C drive or full recovery using the Vaio recovery utility then this will not remove the recovery partition.
If you want peace of mind use the following link to check out the :Troubleshooting and Recovery Guide
vijsingh
So in Vaio Recovery Restore C: Drive & Restore Complete System will not delete the partition, right?
Which one would you reccomend I use? I just want it restored to factory setting like the day it was bought and not to delete anything else.
I will take a look at the PDF when I get home, thanks
Thalamus.
Champion
Recovering C should be fine..
