First Time Wizard
Judy-J
First Time Wizard
Hi, using a vaio laptop for about 10 months and suddenly when accesing s by the Web only button a "First Time Wizard" appears, any idaeas why? only option is to close down and log on normally. Or should I accept the this and install the wizard?
4 REPLIES 4
rich912
Hi Judy-J,
Have you by any chance updated your browser (IE presumably) recently or installed any program that is web based?
Rich
Go n-éirí an bóthar leat
Judy-J
Hi Rich, No not to my knowledge, I'm not to good with PC as you can see, but I dont recall doing so. Should I just accept the Wizard?
rich912
Hi Judy-J,
Chances are that there will be no problem as the message is generated by the browser. It may be prudent to first carry out a full scan for viruses/malware and also create a restore point. If no problems are found with the scan then go ahead with the 'First Time Wizard'.
Rich
Judy-J
Rich
Thanks for the advice, I'll go ahead as you suggest. thanks
