gruezak
fn and s button....
Hi i have fs315s i installed xp pro than i setup drivers from vaio-link.However fs and s buttons doesnt work.I installed vaio control center and when i click to prefences about fn and s buttons it gives error that it says can not open.
Help me 😞
Hi gruezak,
Download the Sony Preinstalled Utilities from VAIO-LINK and expand the download into a temporary folder.
For the function keys to work you will need to install some of the Utilities in the correct order:
1 Sony Utilities (installer folder 1)
2 Sony Shared Library (installer folder 2)
3 Vaio Event Service (installer folder 5)
And then re-boot your Vaio - you may have to repeat the process!
:wink:
gruezak
tnx alot
