Fn key not working after installing windows 7
b11pnd
hey guys,
i have a sony vaio vgn-c1z, i had recently updated it to windows 7 64 bit, now some of my fn keys have stop working e.g. brightness.
also my memory card reader does not seem to work any more.
please will you be able to help me out please
Thanks guys
rich912
Hi b11pnd,
This is a fairly old model that was designed for and came pre-installed with XP and is not supported by Sony for Windows 7. However there are Vista utilities available that may work under Win 7 for the Fn key functions.
Download and install the following from this link (under Windows Vista) in the order given:
http://www.sony.co.uk/support/en/product/VGN-C1Z_B/updates
  • Setting Utility Series
  • Sony Shared Library
  • VAIO Event Service
  • VAIO Control Center
There is no memory card driver available under the Vista upgrade tab. You could try the original XP version but I have no idea whether this will work.
Rich
Go n-éirí an bóthar leat
