FN keys not work
outsider6
FN keys not work
Hello
I have Sony Vaio TX3XP with Windows XP SP3. I cannot use the keys for controlling brightness etc. and vol UP and MUTE buttons do not work.
I dont have find any software to hotkey.
Best regards
outsider
Hi outsider
On 1 March 2018 Sony have stopped listing drivers and utility programs for the XP operating system. Presumably this is because Microsoft have stopped supporting XP.
Unfortunately, this is typical of Sony who will do anything to get out of giving any support to its customers.
I think I will have copies of the files you need - Sony Shared Library and Vaio Event Service - but will need to search backups. I have just seen a PM from you - please send me an email address to send the files. Are you using the original OS or have you installed another copy - if so you may need more files!
Hi outsider
outsider6
I send You PM message
Best Regards
outsider
