my keyboard function keys have stopped working on my laptop PCG-8N2M possibly since I uploaded the latest XP service pack. How can I get them working again?
Solved! Go to Solution.
Hi spock123 that's a golden oldie Vaio yoiu have there.
Please help me with the correct model type - the PCG-8N2M you are quoting is the chassis type from the bottom of the Vaio - is there a model type on the screen surround? I think you probably have a PCG-GRT815E but please confirm.
If you do have a GRT800-Series then you need to download the Original Utilities Package from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=PCG-GRT815E
....and run Utils.exe to reinstall the Utilities responsible for the Function keys.
Alternatively, you may have this already in a folder C:\utils on your Vaio and just need to run it.
Hi
Thanks mate.
It's actually a PCG-GRT815M and yes a bit elderly! But it had c:/utils installed already and running this made it all work again. Thanks
