Cooling issue. The system is heating too fast, the fans go on full-force when windows starts. DVD's are also playing in steps. Sticking and playing at the same time like a faulty Cd.
This happens with brand-new dvds as well.
I think it might be a cooling issue, a manufacturer fault. Or it may have wore out.
Any 1 have any ideas?
I suggest that you download MobileMeter and check your CPU temperature.
And please, only one post is necessary!
