I have just upgrade my laptop to win 7 64bit with clean install (from vista 32bit originally installed). I didn't had any problem with the drivers except the drivers for memory stick card reader. Can anyone help?
Thanks in advance.
Hi nigal9981 and welcome.
There are no new Windows 7 drivers for the MemoryStick device. You need to reinstall the 3 Originally Installed 64-bit Vista Memory Card Reader Writer Drivers Ricoh (MS + SD + SD CPRM) from the download page for the FW41ZJ here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FW41ZJ_H
Thank you very much for your help. I will try it later today and i will let you know.
Regards,
Nikos
