I have tried upgrading my vaio from windows vista home premium 64bit operating sys. to windows 7 home pre. 64 bit. but once i did it i had problems with connecting to the internet i couldnt connect either by wireless or cable.. i tried to install the drivers but i couldnt find a (VAIO SMART NETWORK) update for the 64bit.. has it got anything to to with this software? is that why im having the problmes? I restored the vista and im using it at the moment. I want to upgrade again but im worried ill face the same problems.. any help will be highly appreciated? Thanks
Hi SRT-10 and welcome.
You will find an original installable 64-bit version of: -
VAIO Smart Network 32/64 bits 4.97 MB 29/09/2009
on the 'Originally Installed' Tab at the bottom of the download page for the VGN-FW51ZF here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FW51ZF_H
If you click on the 'Updates' Tab you will find an update: -
VAIO Smart Network - 3.0.3.01220 32/64 bits 5.92 MB 25/02/2010
You must install the original first.
Thnak you so much for you help. before i go through with the update i have one more doubt.... it shouldnt matter tht mine is FW41ZJ and this update is for the FW51ZF right i checked out the specs and its only the ram and speed i should be fine right? Thanks alot for your help
Although I have not tried it on your model, I would expect it to be standard for the model type.
I'm afraid I cannot guarantee success so it is down to you in the end but I would be surprised if it is not OK.
hey there. I have successfully installed windows 7 and it seems to be working perfectly the only small problems im facing is the S1 buton on the keyboard doesnt seem to be working. have you got any clues? and one more thing ..before upgrading when i used to connect an HDMI cable it used to give me the option of choosing the resolution ( 1080, 760, 720) after upgrading that option is gone. do u have an idea if i need to install a certain driver cause if im not mistaken i think i installed all the drivers and utilities on the page. appreciate your help. Thanks
