Hi all apologies if thisbadly written but new to this.
My problem is i want to run my fx503 laptop in ntfs mode,possibly on a new bigger hard drive,how can this be done as the machine comes as fat 32,can i format a new drive and simply instal the programs off the recovery discs?.Any help greatly apreciated [:">]
Also can the movieshaker prog be bought on it`s own to use on another computer as i love it and use it a lot ?
An easier way would be to type
convert c:/fs:ntfs (where c is the drive you wish to convert) at a Command Prompt
You will retain all your settings and files.
