Finally cracked the problem of the built in speakers not turning off when plugging in headphones. Heres how I did it.
1. First installed the original Vista drivers using the update drivers wizard in device manager. Now this doesn't work as it cannot start the driver (code 10 in the error log).
2. I then checked the registry key for the driver which is:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}
Check your registry and you should have the same key. I then navigated to 0015\Settings\pin, within this key, and exported it to pin.reg.
3. Installed a version of the Sigmatel driver I knew worked although headphone issue. Ver 5.10.5067. This was obtained from the FZ19VN XP downgrade.
4. Imported the Pin.reg and rebooted laptop.
This sounds simple but is a result of a lot of time and research, If you don't want to do the above just install the 5.10.5067 drivers and import the pin.reg file listed below.
Please post your results if this also works for you. Only thing left is the S AV and Brightness controls as these are still not working.
Hi SIMON5080.
Thank you for posting this solution. It has been quite a common problem and this will help many others.
Thanks for adding the pin.reg!!!!
Thanks, SIMON5080
In my Vaio VGN-FZ11M the key is:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0026 \Settings\pin]
Thanks, SIMON5080
Within Class, search “pin” and appeared only this.
It works
Works great, thanks!
well if you use the fz11n XP downgrade drivers then you will not have ANY problems at all
Thanks so much SIMON5080. This worked like a dream on my AR51M; the only tiny difference being that pin was in 0017 (just so people know). Thanks again; truly ingenious work!
