I recently downgraded to XP pro from Vista. I solved most of the the problem (that came with the downgrade) except one. Bluetooth doesn't seem to work as it should. It doesn't discover my Bluetooth (Logitech) mouse. It does discover my mobile but gives me the message that something is wrong with a/some modem device. I run the Toshiba Bluetooth stack. Any suggestions?
Thanks in advance!
/Lindaloo
