fz31s.....what battery does this use?
scootbond
hi. i have got hold of a vaio fz31s, but it did not come with a battery. only mains.
can anyone tell me what battery it takes and if there is a long life one also available?
i am in the uk.
many thanks.
scott
Thalamus.
Champion
Hi Scott,
welcome to Club VAIO.. :slight_smile:
As far as I can see the FZ series uses a VGP-BPS8 battery..
If this is correct then I guess the long life battery would be a VGP-BPL8..
If you want to guarantee that the above battery model numbers are correct then I suggest you contact Sony Vaio support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
