Hi, I'm using a RS 324E for a while.
I updated the GP software today (GigaPocket_555513070.exe) and I still having the following two problems.
1>
If I view TV via the GP, the audio is just not sync (when I record TV and watch it back, than the audio is correctly sync). Can this be a overlay thing or what so ever? (I have DirectX 9.0c).
2>
When I record from an external video device (VCR or analog PAL8 videocam).. the recording is not perfect.. just the last 'lines' at the bottom of the captured video are incorrect). First I was thinking that it was something with my VCR, but my cam (and another VCR from a friend) are doing the same. So it's really something in the capture side of the story.
I will try to make a screenshot and put it in my profile.
Can somebody test if his/her TV watching audio is sync, please contact me/post here if you need more information.
Thanks everybody!
the updated giga pocket has issues with sp2, i ended up reverting to the version that came with the machine and it works fine now
