GMA950 for VGN-N11M/W
minex
Hello :smileybatting_eyelashes: I have Sony Vaio VGN-N11M/W computer. I need reinstall windows, and now I can`t found driver for video. CD with drivers i not have. On the computer write that is Intel GMA 950. But this driver is absent. I found just GMA945 but this is not correct. Can you know correct video card name? I be at a loss.Can you help me? :worried: :slight_frown:
Hi minex and welcome to Club Vaio.
What are you trying to do? Are you trying to reinstall the original operating system or are you trying to install a different one.
You can make a Recovery DVD with all the drivers and utilities on by using the Vaio Recovery Utility. You can also restore your Vaio and reinstall the original OS using the same utility.
Start -> All Programs -> Vaio Recovery Tool -> Vaio Recovery Utility.
Your model uses the Mobile Intel® 945GM Express Chipset which includes the Graphics Media Accelerator 950 and you can download the drivers from Intel Downloads
I think the drivers are included in most Vista releases as generic drivers.
If you can explain a bit more what you are trying to do, someone may be able to help.
:thinking:
