Got My Vista Copy Today
a7med_360
Hey, i got my vista copy today, im about to install it just want to clarify these facts.....
Will it delete my partition(recovery) & my D:\ drive and and do i follow the sticky guide on this forum or the book?
Because i just want to install and format the C:\
21 REPLIES 21
apierc1
You received your vista copy today, my comiserations.
a7med_360
thank you :heart_eyes:
topbannana
Recieved mine also.
Once installed Vista Premium , the applications and drivers that come in the package.
What else is required to make to make this VGN-FE31M run as smooth as it did running XP MCE.
Do I need to add more drivers from this site.
Also when doing a clean install the hard drive is formatted as a single drive.
Any good advice for doing this Clean Install with the Discs that came from Moduslink ( Vista Premium , Drivers and Applications )would be much appreciated.
Cheers.
a7med_360
So all partitions are deleted??? is there away around this
a7med_360
anyone? because i want to install vista now :slight_frown:
MattWilson
a7med_360
Ive read that multiple times havent found anything on it that will tell me if it will delete my partitions i have..........
MattWilson
When you install any operating system it should ask you in which partition you want it. It is likely to overwrite your XP partition since it is an upgrade but back everything up and then i won't matter.
a7med_360
The discs only perform a clean install!!!!
