i can't use the gps on my new vaio p11s1e. i tried all the settings,i reinstalled the "vaio location search"software, selected different com ports, etc.and nothing. software is starting, but could not "positioning not possible". could someboby help me. thanks
Silly question - but have you turned on the GPS?
To use the GPS function
1 Turn on the WIRELESS switch.
2 Click the VAIO Smart Network icon on the taskbar.
3 Click the switch next to GPS to toggle it to On in the VAIO Smart Network window.
✍Driver software will be installed when you first activate the GPS function on the VAIO Smart Network.
Install new version of switching utility from support site if you wont to turn on/off GPS without WiFi switched on.
thanks, but i could'nt find "switching utility" on the support site. maybe some help with a link please?
Same problem with same model. Could you find any solution ?
The switching utility is called 'Vaio Smart Network' - check you have the latest version
VAIO Smart Network - 3.3.1.08110 32 / 64 bits 5.69 MB 09/09/2010
You can download it from the support site for your model here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?m=VPCP11S1E_W&l=en_GB
Thanks for your suggestions. I had done all official win 7 and vaio updates. I checked that i have the latest version of vaio smart network utility. Any other recommendation ?
