Graphics card upgrade
ripou
I have a pcg-K115B with an ati radeon fraphics card. I think it mayb a 64mb intergrated one. However, no recent games appear to work. Is it possible to get a graphics card upgrade on a laptop?
profile.country.de_DE.title
seb21__
I have the same graphicscard on my PCG-FR315S.
Yes it's right it's an onboard device and you can change the graphicsram between 32, 64 and 128 MB.
But you can't uprate the graphicscard.
Uprade your RAM to 1GB for more perfomence or put down the graphicsram to 32MB in the BIOS.
TygerTyger
Make sure you have the latest graphics card drivers as well, the Sony ones are useless. Omega Drivers (Google it) are pretty much the 3rd party standard, use at your own risk.
seb21__
The driver updates from Sony doesn't make the graphicscard faster.
It's for more stability.:smileyshame_on_you:
Other Drivers (like the original from ATI) don't function.:smileynerd:
