This probably has a really simple answer but ive looked on google to try and fix this but i cant find anything. Heres the problem: i was messing around on the desktop just moving things etc and then the icons just had a grey border around them they stayed after turning off the pc and its really bugging me.
Not entirely sure what the problem is here Franz, but I would suggest that you carry out a system restore back to a date before the problem occurred. (Start > All Programs > Accessories > System Tools > System Restore).
Good idea thanks
You know on the calendar... only todays date and yesterdays date is in bold
In that case I suggest that you scan your system for viruses/malware!
Ok so what do you suggest next about the grey icons? Is there like a default button for all icons?
Have you scanned for viruses/malware?
Doing it now - Spywear Doctor + Spy Bot.
I might run that trend micro house call one over night
Also carry out a full virus scan.
Ok shal i post back here when they are all done?
