Grinding sound in laptop
timdickinson
Hi all,
This just started a couple of days ago but is pretty loud and really doesn't sound too good so any help would be appreciated.
I've had my Sony Vaio VGN-NR38S/S for about 18 months now and all has been working fine apart from battery issues which is a different matter. But a couple of days ago this really loud grinding noise came from within the laptop, lasted a couple of seconds and then went away and everything went back to normal. I get this sound a couple of times per day but I can't seem to recreate it on demand so I don't think it is anything in particular that I do each time.
The best way to describe the sound would be grinding or metal on metal scratching. Really not a good sound to hear.
Anyway, from having a bit of a search around I get the feeling this might be an fan (possibly the CPU fan if that uses a ball bearing system?) or the hdd.
Thanks for any help on this.
Thalamus.
Champion
Hi timdickinson,
it difficult to tell with sounds, it could be your fan or it could also possibly be your Vaio's HDD..
Is you Vaio still within warranty.?
timdickinson
Thanks for your reply.
Shamefully no, warranty expired a good while ago or I would be sending it back for a check immediately.
The volume of the sound is what's making me think its the fan (is that even relevant?), but I'm hoping its the hdd to be honest. I keep everything backed up and buying a new hdd is pretty cheap sending the Vaio to Sony for repair is not.
Thalamus.
Champion
It could be the fan, and the noise could be due to a build up of dust, etc.
I would suggest, if it's possible, you ask a local pc repair specialist in your area for their opinion hopefully they'll do that for free.
