GRT786M - Recovery disc doesn't contain all the original s/w
ravijain
I had to do a clean install afte upgrading my HD. I used the recovery cd to install. However, it doesn't contain the DVD/writing software "clcikto dvd" etc, nor ms works.
Where can I get these from now ?
kee-lo_
I would contact Sony support.
robpaxton
Some applications have to be installed after the recovery - insert the disc after windows has started and choose application recovery.
Your software manual should detail the procedure.
