Hi! I'm a new member and i want your opinion.
I'm about to buy my first laptop and i don't know if i have made the right choice:
Sony Vaio GRT996VP
Mobile Intel® Pentium® 4 2.8GHz
Microsoft® Windows® XP Professional
512MB DDR SDRAM
512KB Level 2 cache
60GB hard disk
DVD+RW
Onyx-black 16.1" TFT SXGA display !!!!
64MB NVIDIA® GeForce" FX Go5600
16-bit CD-Quality stereo sound with suround capabilities
Wired 10/100 LAN
Wireless 802.11b/g LAN
Internal 56k V.90/V.92 Modem
Floppy disk drive
Li-Ion Battery (upto 2hours battery life)
1Year warranty upgradeable to 3 years
Note that i live in Greece and this is the only Sony Vaio GRT model that i can find.
Is it a good machine? Should i wait for a new model with Hyper Threading?
Thank you very much!!!
(forgive me for my bad english)
The spec is brilliant, I think it's a good buy, but maybe some of the owners could back this up.
Firstly, thanks for your fast reply!!
My only doubt is if i should wait in order to find P4 3 GHz or 3.2 with Hyper Threading.
Will HT make a big difference or it does't worth the extra money.
The rest specs are very good and the cover my needs.
Please help me if you can.
Thanks again!!
Thanks again! You are really fast
I agree with you about HT.
Unfortunately, there is no AMD 64 laptop in greece
Even SONY has only 2 vaio in greek market (GRT996 + Z1)
Do you know if Sony will update the GRT series soon.
If not, i think i buy GRT996
Thanks man!
No idea.
Can you not buy a VAIO from the UK?
Or do you need a Greek XP?
No. Win XP are English version.
How can i buy a sony laptop from UK? From internet?
Will the guaranty "work" in greece, although i will buy it from UK?
Thanks!
sorry for my english
Ah yeah I think you have a good point there, not sure if the warranty works for all Europe, that's something you'd have to ask VAIO Link.
Thanks man!
I'll think about it!
