hard disk speed & special slot on PGC-GRT815E
stemo72
Hi, some one know if my notebook support a new hard disk with 7200 rpm.
under this notebook exist a secondary slot, at the left of the ram slot. what's that?
saluti da Roma.
9 REPLIES 9
Thalamus.
Champion
Hi stemo72
Welcome to the Forum :slight_smile:
I believe this is the multi purpose bay for Second Battery Pack.
Maybe someone could claify this :thinking:
rich912
I think that this is where the Wireless card is fitted in other GRT models.
Go n-éirí an bóthar leat
stemo72
wow..........if it's right, you know the part number of the wirelees card. I've installed two days ago a new wireless lan at home.
so I can canghe the client.
Thalamus.
Champion
Sorry Rich & Stemo72,
I thought that as stemo72 stated it was under his notebook that it was the weight saver.
However I will bow to your superior knowledge Rich :slight_smile:
rich912
Don't get carried away there Thalamus, I have no superior knowledge:smileywink:
The Wireless Lan card is available via a site in the States but to install this may not be as simple as it first appears. The card, as far as I can tell, has a part number of 1-761-784-31.
OK so far but, as I understand, the models that have this 'built-in' also have a wireless switch on the front of the notebook - does yours have this? If not you may also need the 'Slide Wireless Knob', part number 4-673-683-01. Then the question then - is this connected to the WLan card?
Can of worms I fear, but research this yourself at
Nexttronics.
Best of luck!
profile.country.fr_FR.title
micheldelyon
saluti da Roma.
Hello stemo, excuse my bad English. Yes you can put a disk 7200 t/m, I have I meme installed(settled) a disk Hitachi (:HTS721010G9AT00 93.16Go on my GRT815E. Hello of Lyon Michel
stemo72
thank you michel, perfect..... I'm looking for the same hard disk, I thik that with this new part, my pc have a good performance when work with video file.
don't worry for english, it's very busy also for me.
ciao
stemo72
thank you very mouch for the link and for the right information.
only one thing, the price of the wireless card it's incredible......
but in the site I found a lot of technical info.
you have a lunch pay from me when you came in Roma.
ciao
rich912
I will hold you to that.... Roma here we come:smileywink:
