Hard drive needed replacing - how to redownload gate etc.
profile.country.en_IE.title
futureguy
Hi all,
My 10-month old Sony Vaio took a very bad tumble and I had to send it away for repair (insured thankfully!). I got it back today and the hard drive had to be replaced.
Although Windows 7 is on the replaced hard drive, all Sony Vaio softwafe is missing.
Anyone know how I can legally get all this software?
Thalamus.
Champion
Hi futureguy,
I'm guessing that didn't create a set of recovery disc's..
Unfortunately the applications that came pre-installed on your Vaio are not available to download..
You can however, if you wish, purchase a set of recovery discs from Vaio support which should allow you to restore the original Vaio supplied OS and applications..
You can find the contact details for vaio support by either clicking  Support at the top of this page or by using the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then next Select Model..
Then click Log-In
Once logged select Get In Touch.
Then Click on the Out of Warranty tab, then Phone support.
Thalamus.
Champion
Hi futureguy,
Then click Log-In
futureguy
thank you very much  thalamus...e-mail sent! By the way, have you any idea how much this disc might cost?
Thalamus.
Champion
As far as I am aware the price is approximately 35€ (£30), however the price can vary depending on Vaio model..
