I need to change one of my hard drives, does anyone know how to tell which is C and which is D ?
Usually C:\ and D:\ are partitions on the same physical hard drive.
However, this is not always the case as some models do have two physical drives - what model Vaio do you have?
Hi
My Vaio has two seperate hard drives of 500megs each.
Hi
Are they configured in RAID 0?
I do need the Vaio model please.
Why not just remove one at a time? If you take one out and the 😧 drive is no longer visible then you'll know that that's been removed.
If it's any use to you I can confirm that my 😧 drive is furthest from the connection to the motherboard.
Good luck
