It seems the graphic card FX 5600 and the system won't allow me to play those two great games. it might be just a problem regarding to the driver for the graphic card, but would it be possible a hardware issue??
i can only play Homeworld 2 when i re-install the driver, and the game won't work again if i restart my PCG786M,
when i try to play Call of Duty, it gives me a error message, says, Open GL error. is this a software issue??
has anyone overcome those problems?
Homeworld 2 was fine on my GRT715 - been using the 44.68 driver, which I believe is now available from Sony.... if not try some of the drivers on http://www.laptopvideo2go.com/.
Call of duty has played great on my 786m ever since I got it near 4 months ago. Just make sure you have the latest drivers.
