HDD upgrade and warranty
maddin
Hi!
Will I lose the warranty of my PCG-V505CP when I upgrade the HDD?
I also have the warranty plus pack and so the warranty expires in march 2007.
I want to install linux beside windows and 40 GBs are to small for 2 OS and Data.
13 REPLIES 13
maddin
Hi Stephanius and thanks for your detailed answer!
I'm building Desktop Systems since approx. 10 years now and I never damaged anything.
I'm generally a carefully guy. :smileygrin:
So I think I could do that without destroying any part.
But for the first step I will try to use the "old" 40GB HDD.
And if there is no chance to work with this solution, I will replace it with a 80 or 100 GB HDD.
I think with an external HDD it will be very unconfortably.
You have to carry the Notebook, the HDD and the power pack with you.
maddin
Hi all!
I looked once again at the lower surface of my notebook and discovered an extra cover which was totally sepparted from the main-cover.
I removed the 5 screws and there is the HDD.
I think it would be more than easy to replace it.
Watch the pictures:
1 2
profile.country.de_DE.title
seb21__
Which pics.:smileyshocked: There is only a white screen. LOL
added:
LOL, now I see the pics:smileyblush:
kee-lo_
You could possibly buy a pocket hard disk which connects via USB2
