HDMI Patch for VGN-AR31S
Has anyone installed the HDMI Software 071025a Patch for the AR31S yet? Is it only for the AR31S?
I keep looking at the 55.82MB download and keep putting it off. Does it work OK?
:thinking:
4 REPLIES 4
profile.country.pt_PT.title
V57...
the HDMI Software 071025a Patch is for all the AR31 models...
Has anyone successfully installed it?
:thinking:
profile.country.en_GR.title
efpanay
i have ar31s but i guess i dont need it cos it says here:
http://support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=Downloads/NV/D/VID/NV...
that HDMI Software Update Version 071025a
This program will update HDMI firmware to resolve the issue of no audio through HDMI when PC is connected to an HDMI 1.3 equipped display.
since my hd tv is has HDMI v1.2 i guess i dont need it.... i suppose...
profile.country.en_IE.title
dazagro19
i have the same problem with my ar 51su and hdtv, but there is no patch for my model yet, just wondering would it be suitable for 51su? i dont want to take the risk and install it without confirmation...
