Hi all i am about to buy this card tomorow but need a bit info first
new card
from what i have managed to find out it is better than what i have in my pc standard
any info would be great ie will it fit will it be alot better ect ect
seams to be a good price thou :smileygrin:
ok update i have just had a rake around pc worlds site and there are a few cards for around the same cash anyone know what i should be looking out for i am not up on this side of things yet and not realy sure how to compare them with what i have ?all i know is i have a
geforce 4 mx460 64 mb with a tv out
any info or advice on what to go for or look out for would be great
thanks
Any of the 128MB cards should be good, specially ATI's Radeon.
The Geforce FX should be fine too, the only concern I have is the power supply in the machine might not be able to handle ti.
Good luck, and be careful
ATi are definitely the bees knees at the moment. Do a Google for the card name and see if you can find some comparison. They are usually a pretty good way to measure which is the best deal/best performance.
nVidia are also a good bet at the moment...:smileywink:
Or Robs hamster with a paintbrush and easel.
Rob has a hamster? God I don't know much about you guys... LOL Question is do I want to know?:smileylaugh:
Brian is this for the PCV-RX402 computer? If it is quite recent then it may be OK, when I did an upgrade on mine I discovered that if there is insufficent power, some vital parts of the system will not initialise, such as the hard disk (!) caused by the new video card.
If this is the case then a 400Watt power supply or higher with ATX power cables should fit but its hard to say for sure... Insufficient power can be dangerous so be very careful mate!
The problem is James they're non-standard
