Help - Audio drivers dont work for Win XP Pro
FiReDuCk
Hi guyz,
I bought a new sony Vaio VGN-FS415M that come with Windows XP Home so i remove that Win XP Home, i installed Windows XP Pro but now i face a small problem that the speakers dont work at all
i have installed audio drivers from sony website but this doesnt work - i dont know what to do :S
btw - i can hear the the sound when switch on the laptop.
11 REPLIES 11
oninz
Sony Vaio has a recovery disc so you dont need to download the file again from the web. Try removing the audio driver from the device manager then restart your computer. After you restarted it, just let the computer search your drive and install it. Same goes with the other utilities of the vaio...I hope it will work.
hatemski
Hey guys...you should find this bloody driver on www.omegadrivers.com........good luck :slight_smile:
and the Hardware comes from Realtek !!!!
it works
Hatem
