hello all.
just recently got my Vaio Pocket just a quick question.
Im not very technically minded and so was having a problem.where on the Vaio do you put album art and how do you assign it to an album on the player. I have a lot of Music already on the player and was trying to find out how to put album jackets on the player and how to assign them to an album.
Can anybody help
RICHEE
It is actually in the manual...
Anyway, for music already loaded you need to copy the jpeg images into a photo folder on the player e.g. USER_001
Then play the album,
Go to photo viewer, press forward till you are on the correct image, then select the icon to assign this as album art.
Job done
Its easier for track in sonicstage as you jest have to drag the image file to the cd icon for the album.
Then transfer the album to the vaio pocket.
Automan.
