Help please
TEDWOOF
Help please
Hi,i have a vgn-b3vp and have done a complete re-install.Problem is i can not get the volume to work.Which driver do i need?
Also i want to dual install a Linux live cd/dvd but it will not boot from the disc!!!
What to do?Hit it with a hammer?Or hope some nice person here can help me out
thanks in advance
Pete
binbash
Hi Pete,
Have you tried reinstalling all the original drivers from here? http://www.sony.co.uk/support/en/product/VGN-B3VP/updates .
On the linux front, have you gone into the BIOS of your machine and allowed it to boot from CD/DVD? You should probably press one of the following as soon as you swith the laptop on F1, F2, F9, F10 or Del.
Hope this helps
binbash
TEDWOOF
Hi
the only key i hadn`t tried was delete,didn`t work!!!
Cd is set to boot first in bios.
Downloaded original drivers yesterday but will try again
GRRRRRRRRR thanks
