Hi could anyone help me as i dont know alot about a pc
My PCV RX 305 sometimes locks up used to do it now and again (once a week)
now does it every day seems to do it more if i have a few applications running at the same time and the only way to reboot is to power down as nothing happens with ctr/alt/del (does this harm it)
Also on task manager it says my cpu useage is 100% is this correct
Any help would be great and thx in advance
