Can anyone help me with my blu-ray drive?
I have a VGN-AR61s, but the blu-ray drive only plays blu-ray discs intermittently, sometimes it detects them, sometimes not, says the drive is empty. I also cannot burn dvds/cds using the drive. I've tried the updates from the support site but so far, nothing. Rubbish, wouldn't have bothered buying it if I knew this would happen.....
Hi reb_dj and welcome.
Difficult to diagnose from a few lines but intermittent faults are usually hardware related.
If it only plays older BD Titles then perhaps your Blu-Ray player needs updating. Do you have WinDVD BD Update - 8.0.9.754 installed?
For writing discs do you have the Blu-ray Drive Firmware UJ-220B - 1.04080723 updated?
You can download them both from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AR61S#
If you have both of these correctly installed try opening All Programs -> WinDVD BD first and then putting the disc into the drive.
If all these fail you may need to repair or replace the drive.
