Help with new vaio
Philippoussis
Help with new vaio
i own a sony vaio F serie (fj) but i want to buy a new sony vaio,
one that is a little bit faster and better.
But i want to spend a maximum of 1500 dollars.
And i want to have a built in webcam in it.
Can anyone advise me which sony vaio to buy.
One of my wishes is that it a 15.4 inch or smaller screen.
And can anyone maybe explain why he advises that notebook.
I want to have a fast solid notebook for home use. I play games sometimes on it and thats it.
Thank you
7 REPLIES 7
kee-lo_
Are we talking US Dollars?
Philippoussis
yes us dollars
jumpsuit
Why not click on the product links on the site and have a look at the specs? LOL
kee-lo_
What about the higher spec C2?
Philippoussis
well thats what i did..
but i dont know on which specs i need to pay attention..
cause there is differents between processors like some 2.0g pentium will be slower then 1.73 cause it is run different or something that what i heards that why i am asking people that have more knowledge about it.
kee-lo_
Well I'd say a Core Duo > 2Ghz
2GB RAM
An independant graphics card (128MB will do, 256MB if you can)
Blu ray writer, though a super DVD driver will do that can do dual layers.
2-4 USB ports
firewire
gigabit ethernet for the best speeds from your network
haal-kh98
If you are lookin for a vaio to play games on it then choose either from the FE series or AR series, but FE is better as i've read. But if you are looking for a professional gaming machine then check for the Alienware products: www.alienware.co.uk.
Good luck! :slight_smile:
