HELP
jraallan
HELP
After a reboot, the control panel on my laptop says no audio device detected.  How do I restore sound?
chalkywhite
Try disabling then enabling your sound card in Device Manager.  Google this if you're not sure how.   P.s. if u use a bit more text in your thread title, it might encourage others to help.  "Help" is not enough to lure most in to read more. 😉
chalkywhite
pusaqall
I had the same problem 2 days ago. It has been fixed when I restart my PC. Everything went back to normal. A bit weird though.
