Can i reinstall Drag and Drop with out Recovering my hole PC?
Because it got muck up by anther program!
Thanks for your help
Paul
Use your recovery disc. Insert it but dont restart. Choose OK for application recovery and select DragnDrop 2nd from the bottom.
Unfortunately the option to individually install applications has been included on very few recovery disks. Possibly only the premade ones now I think about it.
At any rate, if the option like Tony said isn't there, then you will have to perform a recovery if you want to reinstall it, but TBH if it comes to that I wouldn't bother, it's not a very good program. There are plenty of free alternatives out there, or Nero is excellent if you don't mind paying.
