Vaio update is not available on downgraded models..:smileysad:
You will have to check the Vaio support site to see if there are any XP updates for your vaio..
Hi Mcgregorbart,
What model vaio do you have.?
Are you running the original Sony supplied OS.?
What version of Vaio Update is currently installed on your vaio.?
Thanks for reply
Vaio Model VPCS12V9E
Original OS Disc sony downgraded to XP Pro
No Vaio on at all
Thankyou
