Hibernate???
ranarora
Hibernate???
Jus wonderin if anyone knws how to get the hiberate button back....
I did a dick cleanup, and cleaned up the "Hibernate option" as well... and now as a result have lost the Hibernate button! I still have the "sleep" button, but using this leaves the light thats below the touchpad constantly flashing...
So if anyone knws how to get back the Hibernate button, please let me knw
4 REPLIES 4
soyluoglu
i think you have to estabilish again windows , maybe you can use the recovery of system maybe it might be a solutaion of it, but i think the etsablish windows is the best solutaion of it, best regards
Thalamus.
Champion
Hi Ranjeet,
Yes running a disc clean up can remove the hibernation file and turn off hibernation..
This LINK should provide you with a solution.. :slight_smile:
ranarora
Hi Ranjeet,
Hey Thanks Thalamus, it worked. I've got the hibernate feature back. Appreciate it.
thanks
Thalamus.
Champion
You're welcome Ranjeet.. :slight_smile:
