HMZ-T2 Head Mounted Display Workstation
sapsys
Is it possible to use the HMZ-T2 or any other Head Monuted Display as a workstation display unit ?
I would like to be able to get rid of the screen jungle on my desk, and replace it with a head mounted display. Ths screens take up a lot of desk-space, and they generate a lot of heat.
In my work I often have up to 50 open windows at any given time ( console / terminan / putty ).SInce this is a workstation environmant and not a gaming environment I do not need the gyro functionality ( follow head movement ). It is more a static environmnet for a system administrator.
I know a room full of system administrators wearing Head Mounted Displays and headphones sounds a bit like Star-Trek, but it is still something I would like to explore.
Are there any head muonted display's where this is a possibility ?
Kjell Erik Furnes
0 REPLIES 0
