hot keys!!!! dilemma
kookiez
hi my hotkeys dont work either! i donwloaded the original drivers and opened the zip file but only the couple of the folders have exectuable setup files, the others don't. And just to make things more complicated there is no folder that says hotkeys theres only:- audio, chipset, memorystick, modem, monitor, network, pointing, setreso, sony nc, usb mouse, video1, video2, and wireless lan!
What am i doing wrong dude?!?!?
Oh and i checked that msconfig, system start and the hotkeys file isnt there! where can i find it? HELP!
William
HOTKEYS are dependant on the following:
This list is dependent upon the computer model. If the model came with the driver listed below, install it in the order listed:
1. Sony Shared Library
2. Sony Notebook Control
3. Sony Programmable I/O Control Device
4. Sony Utilities Library
5. Sony UI Library
6. Sony Extended BIOS Dynamic Link Library
7. VAIO® Event Service
rich912
You need the pre-installed utilities.
Go n-éirí an bóthar leat
