Hello,
i am having problem with hotkeys on my vaio.(Fn + F2, F3, F4, F5, F6, F7, F9, F10 or F12 for volume, brightness, sleep presentation mode... )
I install clean version of windows (original retail version, NOT by SONY) on my vaio after having some problem with upgrade version.
I have install all the drivers from the vaio support and yet cannot get the hotkeys to work.
any one got any ideas to getting them working.
i have VAIO VGN-NS11J/S wiht windows 7 32bit.
thanks.
Solved! Go to Solution.
Try reinstalling the following Sony Utilities IN THIS ORDER: -
1. 7UPG_Sony Shared Library
2. 7UPG_Setting Utility Series
3. 7UPG_Vaio Event Service
You can download them from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-NS11J_S&os=10
thanks for replay.
but can you also tell me other important things to install. i mean i dont use sony burning software or any other sony media software. but i want the all the important software.
beside what you told me:
7UPG_Battery Checker Utility - no use
7UPG_VAIO Control Center - ???
7UPG_VAIO Control Color Setting - dont think so.
7UPG_VAIO Power Management - will it help the battery last long?
7UPG_VAIO Presentation Support - does this bring up the menu when pressing Fn + F7 for presentation options?
VAIO Update - 5.1.1.04090 - dont think so.
thnaks.
i know which drivers to download.
7UPG_Graphics Driver (Intel)_type1_32 or Graphics Driver (Intel) - 8.15.10.1872
7UPG_Wireless LAN Driver (Intel)_32
Intel Sata driver registry patch - 080619a
thnaks
