How can I access my Sony Vaio laptop if I have forgotten the password
wilton1968
My sister has a Sony Vaio laptop which has a few login accounts set up for her son and 2 daughters which they have set up themselves.  My youngest niece is unable to remember her password so I have tried to gain access myself via the Administrator login.  However, there is no Adminstrator account on the login screen.  I tried to login as an Administrator by pressing CTRL-ALT-DEL twice which I am able to do on my own desktop which is currently running WINXP.  Unfortunately, as my sisters' laptop is WIN7 this does not work.  We have tried accessing by getting my nephew to log in with the view of setting up an Administrator account but he is not willing to help.
I tried accessing via Safe Mode but unfortunately the same accounts appear on the login screen so at present we are unable to access the laptop to get my youngest nieces' password reset.
Has anyone had this problem themselves.  If so, can someone advise me how it is possible to gain access.
rich912
Hi wilton 1968,
I would suggest kicking your nephew’s arse but political correctness prohibits that, so have a look at the following link – please read the warning regarding making changes to the Windows Registry...
http://www.sevenforums.com/tutorials/85657-password-reset.html
Rich
Go n-éirí an bóthar leat
10 REPLIES 10
rich912
Hi wilton 1968,
Rich
nikkilim
Since you mentioned that there is no option to login as Admin, try this.
Windows Key + L then click on switch user. Then check if there's an option to login as Admin. https://imagicon.info/cat/12-13/vmware_happy.gif
hyeriod
Do you have a password reset disk? Things will be easy if you have one. If you have no disk, you can follow this guide:  3 Easy Ways to Reset Sony Vaio Password
mario.adli
ther is no answer apart from changing operating system,
i do love to help you ,but you have to be in glasgow for me to do that
My Sony Vaio refuses to accept my screen password
Pismosurfer
Can I still get into my laptop
mario.adli
unfortunate you need to chance a window,
7 or 8or 8.1or 10
Malikaiy17
Hi left my laptop about a year now because of illness, now am better from the illness want to use the PC can' remember the password, please I need help
Jkkeas
Faced with such problems, if you can crack password on Sony Vaio laptop , everything will return to normal .
As long how to crack , you can follow it : https://www.tunesbro.com/reset-vaio-laptop-rassword.html
