How can I retrieve a deleted item
gizzmo32
Is it possible to retrieve something I have deleted which is also not in the wastebasket?
rich912
Hi gizzmo32,
This can depend on whether the file has been overwritten but there is free software that can recover deleted files.
Try Undelete 360 or Google 'recover deleted files'.
http://www.undelete360.com/
Rich
Go n-éirí an bóthar leat
rich912
Hi gizzmo32,
Rich
danhague
I have had my own experience on this. First thing you need to do is not to save or delete files on your computer since it will decrease your chances of recovering those files.
There are tons of free softwares like suggested above. Make to to have your security on when exploring other ones. http://imagicon.info/cat/12-13/vbulletin-smile.gif
