How can solve NVIDA Graphics crashes?
bigh141
How can solve a NVIDA Graphics crash?
I have a VAIO notebook model VGN-NR21Z with the NVDIA Geforce 8400M GT GPU the driver date is 19/09/2007 and its version 7.15.11.5665
Over the last few days my screen started failing showing green & white chequers and then fuzzy and the failing leading to a reboot.
i ran some check tests and this shows it is a problem with the above NVIDIA graphics driver.
I have tried updating from system devices but it tell me i am running the latest version of the driver. Is this true as it seems old? 2007?
I seem to have effected a partial repair as it is not happening as often but i am still getting blue screen failures on a fairly regular basis caused by this driver.
Any help gratefully received please
rich912
Hi bigh141,
The original graphics driver for this model is 7.15Q - 7.15.11.5665 dated 28/02/08 and apart from a port replicator graphics driver update (Graphics Driver (DisplayLink) 4.5 - 4.5.13507.0) there is no Sony released update available.
http://www.sony.co.uk/support/en/product/VGN-NR21Z_S/downloads/Preinstalled_Drivers_3611
http://www.sony.co.uk/support/en/product/VGN-NR21Z_S/downloads/EP0000164453_4065
If uninstalling and then reinstalling the driver makes no difference it could be a hardware problem.
Rich
Go n-éirí an bóthar leat
rich912
Hi bigh141,
Rich
